Selects the VRRP version to apply to the VRRP router instance.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID for the VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| v3-v2 |
Specifies VRRP v3 with VRRP v2 compatibility. |
| v3 |
Selects VRRP v3. |
| v2 |
Specifies VRRP v2. |
Configurations created by earlier ExtremeXOS software releases have an implied version of v2. If the configuration is subsequently saved, the version is explicitly set to v2.
None.
The following command configures the VRRP router instance to use VRRP v3 only:
configure vrrp vlan vrrp-1 vrid 1 version v3
This command was first available in ExtremeXOS 12.7.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
